Hi, i have a Boulter Buderus 500-28C combi that works off a Modulink 250RF wireless thermostat. The problem i am getting is the thermostat loses connection with the receiver on the boiler (red light on, should be green). This causes the boiler to periodically switch the heating off for no reason, also doesn't switch off after reaching set temperature and needs commands sending several times before it does as its told! If the boiler was set to come on at 8.00am it would sometimes take till 9.00am before it starts! There is a clear path between the thermostat and the boiler with a distance of about 7 meters. This problem is intermittent. Please help!
