I've inherited a problem garage with the problem house I bought. I now mm n need to replace the roof on my garage and want to add some insulation. I'm going to put it between the ply and the rafters for simplicity. I know I can use foil conferred insulation boards, but what about using floor insulation (http://www.selcobw.com/products/insulation/floor-insulation/jabfloor-70-floor-insulation-2400-x-1200-x-25mm-bba) to save some cost? It's a detached garage that is built of aerocrete bricks and I've lined the inside with 12mm marine ply and flexible tile adhesive to keep the walls from cracking apart. After the roof, I'm going to clad the outside to hide the disaster.
