- Joined
- 11 Jun 2016
- Messages
- 288
- Reaction score
- 16
- Country
The wife wants to sand down a large coffee table. What type of sander is better, a random one or standard one. Don't want to spend too much, as won't be used much(I think) Many thanks.
I'm sure she would be ecstatic with it, but luckily we don't buy each other presents so I can relaxMe thinks Mrs 5oysterman2 is going to be opening a nice random orbiter on Christmas day, of course santa will not forget an increasing grade of sandpaper sheets to go with it starting from a quick stock removal harsh 60grit to a fine 300 or so grit.
Good shoutIf it'll not be used much then buy a secondhand one off Marletplace.
Cheers for thatRandom orbital connected to a vacuum cleaner.
eg https://www.toolstation.com/einhell-400w-125mm-random-orbital-sander/p19993
Has mixed reviews though.
The dewalt 125mm is reasonable quality. Don't think you need forced rotation, its the grit on the sanding discs together with downward pressure that makes the difference.The wife wants to sand down a large coffee table. What type of sander is better, a random one or standard one. Don't want to spend too much, as won't be used much(I think) Many thanks.
I got the Makita B06050 150mm ROS sander with forced rotation, it cost around £300 plus the cost of the sanding discs. I didn't find the forced rotation made a difference on hardwood but using (and frequently changing) 40 grit paper did when the varnish and ingrained dirt wouldn't come out even with 60 grit. I am not convinced the Festool would have made a difference, though everyone raves about the extraction efficiency of their vacuums. I just hooked the Makita up to a wet and dry Nilfisk which is pretty efficient. £300 is a lot to pay but I was re sanding a damaged/dirty area of engineered floorboards and replacing them was a far more expensive option.Very likely to be better quality than the one I linked to but it is over the OP's budget.
Disclaimer: I am a tool snob decorator. Some of my sanders are in excess of £700, but it would be madness for the OP to pay that much.
Its geared I think so random but stays rotating because of the direct rotational driveWhen you say "forced rotation" do you mean the option to change the sanding mode from random orbital to eccentric? If I need to remove stock quickly, I will put my Festool Rotex 150mm into "angry" mode (eccentric), and then drop down to random orbital. Angry mode will leave scratch marks (depending on the grit used).
My largest festool sander the RAS 180. It is rotary only and a tad too aggressive for most decorating jobs that I do. It is also very heavy.
Nilfisk- yes they make some very good dust extractors. A Festool antistatic hose will be about £100. the Nilfisk equivalent will be about 40% cheaper.
