Hey everyone, I am in the middle of building an entertainment unit for my living room using some 12mm MDF, I have got all the wood cut but have a few problems.
Some of the bits of mdf are warped slightly, should I just screw it altogether and it will eventually straighten up or will I need to fix this before fixing it all together.
Also I am not sure on the best way to screw it all together, I was going to use those small plastic square connectos to screw it all together and not sure this is the best to use? There wont be much weight on the unit as the TV will be wall mounted so will just be amps, ps3, sky etc.
What is the best way to make sure that I screw it all together flush, would it be easier to assemble with a friend?
Some bits I got cut a bit too big so will need to plain these back, I am assuming this should be a problem, it will only be a milimeter or two along the front face of the wood.
What is the best way to finish the wood after, is it possible to hide any of the joining lines so it all looks like one piece? I have been told just to seal with pva glue then paint with water based paint.
Thanks for any help, I have done much with wood before so any help would be appreciated.
