Hi
I have just finished building a small raised patio area.
I was recommended by a handyman I know that I could lay a sand base and then just sprinkle some cement on before i laid each slab (400mm x 400mm) for stability.
We laid a base of hardcore and then just about 1cm of sand, flattened it and then sprinkled some cement powder on before laying the slabs.
However just realized that we have made a mistake insofar as we used builders sand rather than sharp sand for the base above the hardcore.
After some reading I can see this was obviously the wrong thing to do. What I want to know is if we need to take all the pavers up and relay or if it will likely be fine. Im hoping that because it was just a thin layer over hardcore it wont be a problem??
After reading through articles I can see we have clearly done it wrong so I am not trying to find out if this is a viable method. Just wondering if it will likely be okay or if it all needs redoing? Thanks
