Hi There all,
I am in the process of building a garage/room at the back of my garden. It will be built using concrete breeze blocks 440x215x100mm and the approx dimensions are LxWxH 3m(10ft) x 9m(30ft) x 2m (7ft)
There is an old wooden shed which is coming down and the floor has slabs at the moment.
Is it better to build the walls first and then lay the concrete floor or shall i lay the concrete floor first?
When digging foundations for the walls , will 3ft be enough or shall i go deeper
when laying the floor i have been advised to have the
subfloor 150mm deep
sandblind 50mm
DPM 1000 gauge
concrete 100m
there is a large area and i was enquiring if it is better to buy in ready mix or shall i mix myself? if so what mixture would you recommend?
Any help will be appreciated as this is the first of my projects.
subfloor 150mm deep
sandblind 50mm
DPM 1000 gauge
concrete 100m
