I am looking to build a new garden wall that is approximately 6ft high x 2ft x 20 metres. The wall will contain 2 curves that almost go through 90 degrees. The wall should match the existing wall that forms 1/3rd of our property boundary. We have PP and LBC for the wall provided it matches the existing wall (see pictures). As an 'enthusiastic' DIYer the following questions immediately spring to mind:
1. What is the best way to go about building the wall?
2. Should we lay an internal block wall and face it with the same stone as the existing wall?
3. What depth of footing should we use?
4. Where can we get a sufficient quantity of stone?
5. What would be the approximate cost of building such a wall?
Any help/advice would be appreciated.
