Hi Guys,
Background:
Im thinking about building a large shed in my back garden, outside dimensions to be 5.4m x 5.4m, with a pent roof, the highest point being 2.5m tall.
I will build the shed from scratch, im thinking about using a timber frame and shiplap.
Ive built sheds in the past, and literally screwed the 4 sides together, however nothing anywhere near this size.
The roof will likely be cement fibre sheets.
For the roof beams, Ive looked at span charts, and for a a 0.5-0.75 knm2 dead load, I can span around 5.5m using 220x75mm c16 timber, with a 400mm joist spacing.
Questions:
1 - With regards to the roof, what dead load would I use, and would I need to factor in a live load, such as snow? Im hoping to use the shallowest timber I can get away with to maximize head space inside the shed.
2 - Are there any special considerations I need to factor in with building a shed of this size (i.e. wind resistance etc)?
3 - Will it be acceptable to simply screw the 4 sides of the shed together and secure it to the foundation? Or should I sink posts into the ground and secure the sides to the posts?
Background:
Questions:
