T
thatbloke
i am building a roof on my lean to. the existing roof is 10 meters by 3.15 meters and is made from corrugated cement.
the 10 meter span is interrupted internally by a clay lump wall around 3.5 meters from the end of the lean to , all the external walls are clay lump.
i have a good idea of what size of rafters to use but would i get away without using a purlin? the roof is quite a shallow pitch and i will be using ceder shingles over a felt , counter batten then batten.
also , should my ridge plate be the same size as my rafters?
thanks.
thanks.
