Hello,
I'm new to the forum having followed it for many years. I know my first question is slightly odd but I'd appreciate the help having been unable to find it else where.
I'm thinking of building a single skin shed at the bottom of my garden later this year.
To get more space on the inside without having to apply for planning permission I'm thinking of digging down into the ground a few feet to gain more room on the inside.
I've spoken to my local planning office because I could find no information about it on the planning portal. Believe it or not they said that it would be fine based on the grounds you don't need planning permission for a swimming pool.
If, for example, I go one meter below ground and 2.5 meters above my internal wall height would be 3.5 meters. All 4 walls will be 3m long.
My question is, would 10cm concrete blocks with a pier on each wall give me a strong enough structure? The reason I've chosen single skin is to save on building materials and space.
What is the maximum height I could build a single skin outbuilding using 10cm concrete blocks?
(To deal with the obvious issue of damp I intend to tank the structure up to the damp proof course.)
Many thanks,
Ian
Many thanks,
Ian
