I have a small brick step 1 coarse high built internally next to my back door that I've made out of engineering bricks. I'd like to tile it to finish it, but need to prepare a flat and level top to it first and I'm not sure if it's possible to tile directly onto the side of an engineering brick (I've set the bricks down as level as I can, but it's not perfect). I'm wondering what the best way to proceed is? Possibilities I've thought of:-
build a wooden frame around it and pour in concrete or some form of self levelling compound, then tile that. Not sure if this would just crack?
Render it with sand/cement then tile over that. Would render stick to the engineering bricks? I could scratch up the surfaces first with an angle grinder if needed?
Screw plasterboard/tile backerboard and tile that. Not a fan of this though.
