Hi Everyone,
I potentially have bitten off more than I can chew here but I've started so I intend to finish but I'm hitting knowledge gaps along the way...
The Plan
1. Burry 3x 210 litre barrel's into the ground (below a future patch of clover grass) in a central point in the garden. This is done. Each barrel is sunk below ground level into clay soil and joined together using pond connections and pipes; Perforated pipes run rain water into these barrels;
2. Develop the concept of a removable platform with a permeable base that can be removed for any necessary maintenance requirements for access to the barrels; For this, the best idea I have is to create some concrete piles next to the barrels and cut down an aluminium ladder to span between them, a sedum roof base would then sit supported by the ladder rails and on top of this would be soil and clover;
3. Next stage is where I'm stuck. I need a pump that would have sufficient power to draw water from below the ground to 1) be drained and removed from the garden to prevent flooding and 2) be used to automatically water the garden in the summer by using a solar powered setup;
4. Fourth stage is to purchase the irrigation system that would run around the garden between the beds (mostly underground using old pond pipework);
5. Replace top soil and plant clover.
This is the first time I've tried writing this down so don't know if I've communicated that well but I'm stumped by part 3 at the moment but any thoughts on 2, 3 or 4 would be amazing if anyone has something to share.
Thanks,
Chris
The Plan
Thanks,
Chris
