- Joined
- 27 Aug 2016
- Messages
- 18
- Reaction score
- 0
- Country
Hi there, first post here, but given what I'm starting I'm sure it will be the first of many.
About to move into (providing it all goes through) a house that I intend to renovate. but building control seemed like a bit of a minefield and then when i rang them it just got worse. speaking to a friend who's halfway through a much bigger renovation he seemed to be getting on a lot better with the local BCO, but he's also in a different county to me.
Im not in the house yet, so things are liable to change, but a short list of things i want to do.
Boiler moving from utility to the garage.
the utility which currently has a room of it WC/handbasin in it moving round and possibly adding a shower room in there too (theres currently a self contained shower in the garage, where id be wanting to put the boiler, but believe it was never signed off by building control).
removal of an internal none load bearing stud wall.
previously the owner had when they had their extension done had the lounge/diner knocked through into one massive room, i intend to erect a new stud wall there to put it back to how it was. (doesn't effect fire exits as the removal of the stud wall above would make a huge kitchen diner, with 2 external doors).
installation of a log burner/2, most likely with the building of a fake chimney breast( block built till the level of the double flue) then either boarded or just continue with block work up to the height go the single story extension, then double flu'd up to above the gutter line as per building regs.
Installation of a new kitchen.
Installation of a new bathroom.
now I have no issues with building control coming out, given that they exist to make sure a job is done correctly and safely. even if it does involve multiple visits.
but as i have never dealt the building control before( I've laboured on sites a handful of times, am a fairly competent DIY'er and have friends in various trades that will help me out if/when i get stuck).I decided to make a phone call to the local BCO first to try and clear some things up, and it just made things confusing.
1) the costs, if what he was telling me was right, they end up being huge.
was quoted over £800 for the inspection of the wood burners and the chimney.
the other alterations he said it depended on whether they were all being carried out at the same time, otherwise they would have to be classed as individual projects, however he was very very grey about the same time. As in i didn't really get a definitive answer about whether he would need to come out and view everything on the same visit to count it as the same project, or whether him coming to check the kitchen water was plumbed correctly on a tuesday, then to check id plumbed the new ensuite water and installed the stud wall at the end of the kitchen diner correctly on a friday would count as 1 project for a renovation running between £10 and £20k, or 3 separate projects running various costs.
he was also a little bit grey about total cost as a sliding scale ( as for example, for me to remove a stud wall the cost to myself is £0, granted id need a bit in materials to make good the repairs but as this was part of the kitchen installation, id be doing it all at the "same time") Likewise for me to install a stud wall is going to cost very little, but if i was to get someone in to do it,I could be talking a lot.
Im not going to be touching Gas, as I can't legally, and despite working labouring for a spark a few summers back and being asked to run cables and wire stuff for him, Im probably not going to touch the electrics, reason being he's still a close friend and will do the work required for less than the £180 building control want to inspect it.(providing i supply the materials/brews/lunch, which I would be doing for myself anyway).
Im basically wondering what everyone else on here has done? and if so have building control been that anal or have i just been unlucky in whats been said?
as the way it looks from the costs, It would almost be cheaper to get professionals in for most of the work(which I'm already tempted to do with the stoves and a HETAS engineer).
Likewise seems nuts that if was to leave everything where it is in the bathroom, no building control needed, as I'm looking to move the sink about 6 inches to put it in an inbuilt vanity unit I need to inform building control, even though its already plumbed with speed fit which Id even trust the other half to use.
It also seems daft that I'm 90% sure half the professionally installed kitchens/bathrooms/ stud wall installations are either not done by "qualified" people or the work is never registered with building control, but id rather do everything by the book if possible, but I don't want to pay some kitchen installer £11000 for £3000 worth of kitchen units, and about £800 of sundries and a weeks work which they may well not do to high standards.
Thanks in advance for any replies.
