Some of you may have seen my recent thread in the building forum regarding insulation requirements if building a wall with an aerated foundation block.
It turns out that to comply with regs around 55mm of Kingspan is needed, yet when I spoke to my local BC office I was informed that the BI had passed the walls and accepted that no insulation would be installed.
She has not requested that more insulation should be installed elsewhere to offset the difference.
The same building surveyor made me jump through hoops to get the drawings approved, and yet seems to have no issue with the builder not complying with regs.
So what's the point of Building Control if they allow builders to flout the regs. I know discretion is allowed but this seems a bit much.
