Hi all,
As part of my kitchen renovations, its getting a new door frame/liner.
The old one was in awful condition plus a non stand door width.
Im widening it to suitable for 762mm door width.
Few questions.
The wall seems an odd thickness (1930's house), at the top its 80, and further down its about 77mm.
Im going to skim the walls after the door frame is on, so the frame will be about 86mm thick.
I was going to make the sides out of this wood, and plane it narrower to suit:
http://www.diy.com/departments/timber-smooth-t29mm-w89mm-l2400mm/249697_BQ.prd
The original top piece I have left in. This appears to be acting as a lintel, which just bricks above it, is this correct? If so, I'm wary of removing it, and may leave it in.
Is mortar right to use to fill the gaps between the uneven wall edge and wood lining?
One side of the door is against the wall. any tips on doing the door frame/architrave when its against a wall?
Many thanks,
Dan.
Few questions.
Many thanks,
Dan.
