Hi
I wish to knock down the old garage and build a new one with breeze blocks on a floating(10 inches thick) concrete base with pilling on the corners. On top I intend building the walls with breeze blocks. Should I use aerated or concrete blocks as it will only carry the roof as it weight-plywood and bituman sheet roof.
Please give me some advice which block should I use?
Aerated blocks are indeed easier to lay. Would it be suitable as an external wall? Should I use solid 100 thick concrete blocks?
I intend educating myself first then attempt this work.
Please advise
diyboy2
Please advise
diyboy2
