Building over a surface drain
2 Dec 2009
Essex
Any advice on capping a surface drain prior to laying an oversite for a conservatory
I have two drains to the rear of the property both are gully types with a grid and collect rainwater and currently have feeds entering them from the bathroom and kitchen waste
these feeds are being moved into the soil stack to go into the foul sewer and hence both gullies are no longer required
I'm told by building control they are not a shared sewer and i will probably not need rodding access from the property
is it a case of capping them off before laying the base (I've been told by various builders to simply stuff with newspaper and pour concrete in)
Do i need to present these via a sealed manhole cover into the conservatory for rodding access to be on the safe side?
I've also seen a stub stack approach but again i don't want this to protrude through the new floor
Andy
Is the gully a Victorian salt glaze with a brick surround. Is it a plastic one , sort of 10 years old. What is its level like compared with the base?
Frank
