I'm due to complete on a new home which has only just been built (in the last 6 months) The loft insulation is 225mm thick in total, though current regulations state that it should be 270mm.
The site manager says this is because the regulations used in the spec were from when the property was approved by planning many years ago.
I've found out that in 2003, the regulations were changed that insulation should be 270mm thick.
Is it true that regulations which were in place over 10 years can be used on current builds if that was when planning was passed ?
