I want to install spotlights into my bathroom. If I do this using low voltage lighting, with IP65 rated fittings and keep the HV cabling and transformers in teh loft, then my understanding is that I ca do this within the building regs as minor work as only 12v will be entering the bathroom and all HV voltage is outside in the loft.
Is this correct?
Is this correct?
