Dear all
We are converting a 8X8 garage (lawful development) and have two wooden windows of old we would like to keep. The garage is single skin so we are making inner stud walls (room-in-a-room construction) with sound bloc plasterboard & appropriate insulation.
The wooden windows are in a good condition with around 6-7 cm thick frames and are single glazed (3-4mm). I would like to keep the frames, re-affix them at a slightly lower height, and draught-proof them well. Also would like to replace the present panes with 8.8 acoustic laminated glass (there is enough thickness to the frame etc though will need to upgrade hinges). Then the inner leaf (the stud wall) will get the secondary glazing with 10.8mm acoustic glass. The primary purpose is high degree of sound insulation, but also keep the building regs happy. We are not a listed building.
Will that be something acceptable to building regs? If I am using the same frames, changing the glass & draught-proofing them, can they force us to change to double glaze? I guess secondary glaze is double glaze on the double (excuse the pun).
Cheers
Fib
Cheers
Fib
