I'm currently mid-build on a 1.6m deep x 2.8m wide porch. I've been told by the builders that I can't put the door where I want to (very close to one edge) because building regs require a >600mm return. Something to do with making sure the wall doesn't get blown over. We live near London so low wind risk.
I've been lead to believe that if a structural engineer can provide calculations to support a smaller return that it should be accepted by the building inspector. Can anybody tell me if that is true and what the likely result would be (we're hoping for ~400mm return external with a 300mm cavity wall)?
Cheers
Cheers
