I want to convert a large double living room into two rooms using light weight demoutable partitioning. The work is not a material and it is not necessary to apply for building regulation approval to partition the room. If however I need to wire up a new circuit, I will be required to send a building notice.
The mains sockets are in the right places.
Two light fittings one in each half of the room in the right place.
A dual gang switch at the entrance of the room ( operate independently).
If I create two rooms, the current switch will be in the small hallway created in the process of partitioning.
I will need two separate switches at the entrance to each room.
It is possible to wire up new switches from where the existing dual gang switch is postioned to the entrance of each room without wiring new circuit?
Another point - it would be nice to install a wall light in the small hallway (but not vital). Can this be done using existing circuit ?
