I am an amateur at this sort of stuff so if i use wrong words please be patient.
I have a 3 year old chalet bungalow that has 94wx98h (GGL P04) velux window in back bedroom above head height. I now have planning permission to install an addition window of the same type below the existing window.
The existing window is installed tight between 175x50 joists which have been doubled up when the place was built. Above and below the new window are 175x50 single stretchers (i think this is the term).
There will be 100mm between windows which it seems is normal for flashings etc.
My options seem to be to leave the existing lower stretcher in place or double it with an additional stretcher and place either single or double stretchers below which I would attach to "crippled?" rafter below after cutting and sides.
I wish to make the stretcher below the existing window much narrowr so would like to replace it with 50x50 so it would not be so intrusive inside.
Do you guys think I would get away with place a double 50x50 between the two frames and then a double 175x50 below the new lower frame?
Building regs must have agreed the original with one stretcher rather than 2.
I wish to do the job and take loads of photos and then ask for retrospective BR approval which may not be the best approach. If worst comes to worst can replace middle stretchers.
Also if I did decide to go for BR before doing the job would I need to get professional drawings etc.
Can anyone advise please?
