I am building an extension and am thinking of building in the floor joists rather than using joist hangers. In one section the joists would have to be cut into the existing brick wall (the other end will be block). I am looking for some advice on the following:
1.On what do I bed the joists i.e. just on a layer of sand/cement - if so how
thick
2What do I need to do around the edge and top of the joists i.e. leave a
slight gap, fill with sand/cement etc.
In another section of the extension I will have joists running from opposing directions which will end on top of a partition wall (block). i.e. there will be the ends of two joists adjacent to each other with one running in one ditrection and the other in the other direction. Should I bolt the two ends together or not?
Finally, I will construct a block wall on the first floor under which I will have 4 joists bolted together (easier to handle than using a steel beam I thought). Do I treat these 4 joists the same as a single joist with respect to building them in and how do I start the block wall i.e. do I literally bed the blocks on mortar straight onto the joists (the floor boards would then abut the wall)
thick
