Hi all,
Recently posted re: advice on brick laying skills - whilst I'm looking into a few local courses I want to commence with a simple brick BBQ in the back garden.
The only place I can place it is against the back wall of the house (next to patio doors) - this will be a pretty simple affair as we probably won't be in the same house as of next year. I've found a few guides online so I'm relatively confident I can pull this off (something like this):
http://www.acheson-glover.com/community/build-a-brick-barbeque.asp
Simple grill and charcoal kit (if I can find one cheap enough) and an 'extension' to the side for various 'implements'...and most likely alcoholic lubricants : ) (I'll use a small slab and may tile this in a few slates of granite etc)
I'd also like to place doors on there, although that would no doubt complicate matters...
Question is, as the base will be on slightly uneven tarmac path (which goes around the whole house) should I be thinking of building a base first or just level with mortar?
Also, might it be worth grabbing a 'bricky tool' for this job or due to the low key nature just grab a decent trowel and level (would I need a set square too?)
Most likely be starting this weekend - will pop to the local brick merchants and get a few prices (after the common/rustic type brick).
Many thanks.
Many thanks.
