Hi there,
I'm thinking about trying my hand at some woodwork and coinicidentally there is a rather large space under my stairs that could be better used.
So my plan was to make something like pull out kicthen cupboards of varying heights (and then attach appropriately cut doors to the inner cabinet moving part).
Hope this is making sense!
So to start off I need to build the carcass and here comes the first batch of questions.
1. Which material should I use - Conti board or some kind of ply or something else. I was thinking conti board as it's used in most kitchen cabinets I've seen but I am a little worried about it breaking apart when I'm trying to cut and bind pieces?
2. I assume I should make them with 2 side pieces with the bottom and top plate sitting inside the length of the side pieces (rather than the sides sitting inside of the top and bottom piece) as weight is likely to want to make the bottom plate fall out?
3. Which fittings are best used - dowels and glue, but what other fixings are good to hold it it place - screws or some kind of ikea esque pin rod and tightening retainer?
4. Where can you get suitable runners that would be able to work on the pull out inner cabinet - and is it best to have these top/bottom or on the sides - or in all directions (although that's likely to cause alighment gripes!)
As I understand that better I reserve the right to have more questions!!
Thanks for any advice that can be given!
