Building Steps
11 Apr 2007
Cornwall
My garden is on two levels with a 450mm high block wall `stepping` up from the 1st to 2nd level. I want to build brick/paving slab steps against the wall and to make them look more decorative i`d like to make them a semi-circular shape aprox 750mm rad out from the wall face x 1500mm wide (overall dims).
I think I need a 75mm concrete base? to start with for the steps to sit on but other than this i`m stuck as to how to get the curve with the bricks etc. Are there shaped bricks/slabs available for example? I`ve seen kits in catalogues and on the net for complete circular steps but not for half rounds. Any advice or help gratefully welcomed.
Mike
Mike
use half the "kit" you have seen for each step
Thanks for the advice Breezer but I was hoping to avoid having to buy the whole kit and only use half.
