building survey damp issues
31 Aug 2014
London
hi first time poster, i'm a first time buyer and i've just had a building survey report already for the house i'm buying its been empty for almost a year now and its noted Higher than desirable damp meter readings, What does it mean? and it is worth to hire specialist to do further investigation? thanks in advance :)
Without a context its difficult to advise you.
Why not post some pics of affected areas, and the relevant quotes from the report.
Its possibly simply a matter of condensation in an empty house - which is often the case.
Thanks ree,hopefully it just a simply condensation because the last i viewed the house its a mid terrace house approximate year of constraction 1900 i haven't seen any damp spot in the walls,ceiling even in the floor by the way its laminated floor and the 3 bedroom upstairs are laminated as well only the stairs is carpeted. that's why i'm just wondering when i received the valuation report there is essential repairs required and the detail is higher than desirable damp meter readings, i rang the agent and booked again for another view and i'll have a look every rooms thanks again :D
thanks in advance for any advice :)
Your friendly building surveyor will have spent most of his time wandering around with his moisture meter, putting it on the walls and if it says damp he puts a tick in his damp box and advises that you need further checks, im sure he can recommend you a suitable damp company too.
And the damp company will find even more damp and can reliably be expected to rip you off. :(
@OP, don't be rushed into anything, as shown by the above responses. Empty houses locked up for a year invariably come across as 'damp'.
Really, it's just lack of heating and ventilation.
