R
richard7761
The wall is a half-brick one.
I've taken the fireplace lintel away, and I'm filling the fireplace opening with brickwork.
The wall is load-bearing.
Given that the fireplace opening was 1.2m high x 0.5m wide my new brickwork therefore has the same dimensions.
Okay, as it happens I'm now left with a 7mm space between the top of my new brickwork and the original brickwork. My new brickwork of course should take the load above it and transfer it to the foundations.
How can I ensure that happens? I'm thinking of simply ensuring the 7mm gap is filled with cement. In other words, not hammering in, say, a metal shim.
It should be noted that the original wall is going to be cut in half, and that cutting point, along the original wall, is the position where the fireplace opening terminated on it's right hand side.
