Building walls and foundations
17 Jan 2007
Yorkshire
I need to build a 7 ft retaining wall. I was planning on using 4" concrete blocks laid sidewards.
Im wanting to know.
1. What size footing would be required
2. What mix of concrete I should use and what mix for the mortar
Im also building a few raised beds which will be around 1m in height.
Thanks in advance
Andy
Im wanting to know.
Thanks in advance
Andy
You should really get a 7 ft retaining wall properly designed. Rule of thumb says that the base should be 1/4 the height, so you should be building the base at least 550mm wide. But I really wouldn't want to rely on that for a 2.1m high retaining wall...
Better to have a properly designed reinforced block wall with an RC base, which is much less likely to fall over.
(You beat me to it! This was double-posted)
Glad we agree then :p
