The original Powerwall had some pretty specific requirements, I didn't go on the course but one of my bosses did (no idea why!) but there's a lot of things you need to have that they don't advertise, I can't remember them all but it's all to do with space and distance from your consumer unit I think.
Plus the thing weighs around 100kg, so you'd better build the wall you want it on out of granite!
You can install them outside, but you cannot install them anywhere other than a ground floor (100kg). They also hum and buzz so you wouldn't want it in a room you spend any time in.
In terms of allowing for PV, you'd want a cable from where your consumer unit is (to a meter/isolator then to your consumer unit) to the roof space where you'd want PV. This is typically a 2.5mm² cable for a typical array or 4mm² if you've want to cram loads of panels on. Would need to be calculated to work out the exact size, but doesn't hurt to go bigger.
You will also need somewhere in the loft space to mount the inverter, they're nowhere near 100kg but they can be quite large. A wall is best but they can be fitted to timber fixed to the purlins
The payback time on a Powerwall in this country is estimated to be >10 years, and with a warranty period of 10 years, you might end up never actually making your money back. Return on investment on solar has also changed drastically since the feed in tariff took a nose dive at the start of the year.
We're only really fitting solar on new builds now that require it for planning/to meet SAP calculations
