I've searched on here but this seems an odd one. I have an Oliver International built-in cistern on which the internal overflow initially appeared to be running.
However, on examination the float valve is operating correctly and it appears that there is a leak into the delivery tube to the WC pan from the bulk water in the cistern. I think this because the "overflow" runs even with the cistern almost empty and water supply shut off.
I can't see any obvoius method of removing the syphon assembly to check the body for cracks or other sealing issues without demolishing the bathroom wall! Any thoughts?
