Built in electric oven
11 Sep 2013
Kent
Can anyone please help. Am trying to find an oven to fit the following gap measurements.
Height 560mm
Width 600mm
Depth 580mm
Have been looking but only ever one or non of the measurements fit.
Have a baumatic B100ss in there at the moment but its now broken.
The width and depth seem standard to me, and I can find Bosch single ovens that are 15mm bigger than your space.... in fact I think they are 'standard size'.
Is there any possibility of making your space a little taller? Is it an under counter oven, or in a tall housing?
Height 560mm
Width 600mm
Depth 580mm
Your problem is with the height - standard is between 590 - 595.
There are a number of single ovens from whirlpool that are 480 in height.
Most built under/tall oven units have an adjustable bottom shelf that should go up to 600mm in height - are you sure you cannot change this shelf's height?
Its in a tall housing. :)
The questions are all relating to the dimensions of the device.
Surely this is an APPLIANCE query?
Or are we supposed to answer questions about a SATNAV that doesnt work because it is "Electric"
