Have just bought a double built-in oven to replace my old single built in oven.
The new oven will be hard wired directly into the exising 6mm oven circuit and plated over so no problems there.
Question 1... the old single is oven is plugged (13amp) and was connected directly into the oven circuit via a 13am socket... can this now be plugged directly into a ring circuit elsewhere (2.5mm) or must it be re-connected to a separate 6mm circuit ???(plug and all). I am gussing that this has no more than a 3.2kw output
Question 2. I found it a bit odd that the single oven runs on 2.5mm cable (with a fused plug) directly into the 6mm oven supply.
Is this normal ??
Is this normal ??
