Hi all,
I've just moved to a 1928-built semi-detached house, which has a built-in wardrobes in the master bed. It is fitted between the internal wall and the chimney breast (with a cast-iron fireplace). The doors are 1930s-style 2-over-1 panel, and it fits into the skirting and picture rail. They are approx 180x49cm.
I would like to have an extra wardrobe fitted at the other side of the fireplace, between the chimney breast and the bay window. This space is wider, so I may need three doors, perhaps each slightly narrower. I was also thinking of having it made slightly deeper, as the existing one is shallow.
Are there places I could buy suitable doors from? Or do I need to find a joiner to make something up? If I found some doors, would a joiner be happy to alter and fit them as necessary?
I actually had a joiner round earlier, and he said he'd fit some MDF shelves and hang two modern doors (those cardboard things you get in new-build houses). Not quite what I want.
P.S. I can attend to the internals (shelves/rails/etc.) myself. I just don't have the skill to do neat trim and build/hang doors!
P.P.S. Here the existing:
