Bulbs blowing.
8 Feb 2004
Wolverhampton
I have replaced my 2 ceiling fans in the living room (18 x 12 ft) and instead installed 10 mains downlighters, 5 on each side.
They all work great but I have lost 4 bulbs in a week which are 60 watt reflector spotlights 63 mm and are Wilko own brand.
Any idea why this is happening or should I move down to 40 watt bulbs?
I have never seen wilko before, would you consider them to be a cheaper brand?
How are these lights switched?
They are Wilkinson own brand. 4 for £1.79.:oops:
They are switched in 2 lots of 5.
The feed for the fan I removed now supplying 5 downlighters which are double insulated and are 60 watt max.
Well I think your first approach would be to try some slightly more expensive lamps, osram , phillips etc seem good. I do often say to people 'cheap bulbs' but in my experience it is sometimes the solution.
If the lamps are ES or SES make sure you install them with a sound contact to the centre pin. A loose lamp could flicker and blow fairly easily
Were they cheap fittings, it is more likely cheap lampholders causing it.
A lot of them have plastic type ones rather than the ceramic ones of the past.
Hence the 60 watt max rating.
Hispot halogen lamps are nice replacements for reflector lamps, but are costly and do not tend to last long.
Consider fitting a dimmer, by dimming about 10% you greatly increase the life of them reflector lamps
By using a slighty more expensive dimmer with a ramp up feature lamps seem to last longer, but it all depends on the quality of the lamps in the first place.
