altec said:
(a) faulty power Tx
(b) symetrical windings
(c) alternator sets
(d) SWA
(e) AFT Correction
Also I note FWL speaks about a disconnection time of 5 secs should a fault occur. Does this refer to a short circuit fault (5secs seems like a very long time) or an overload or what exactly?
Faulty Power Tx refers to power transformer. What I am referring to is the 11KV/415V three phase transformers located in substaions on street corners, in building and on poles. They varyn in size depending on the load to be put through them.
Symetrical windings was simply a term I used I jnew BR would understand what it meant. The windings of any 3 phase power transformer must be symetrical, ie, all three input and all three output windings must have the same number of turns forming the respective windings and the ratio's must be the same to ensure that the output of all three phases is identical.
Alternator sets = the very large Alternators used for Power generation in Power Stations
SWA = Steel Wire Armoured, this is a type of cable used in the electrical industry.
AFT correction??? Not sure where you got that one from so without any context I cannot see what you mean. The nearest I can think of at this time of night is Power Factor Correction (PFC), and if that is it, I will not enter such a discussion here at 11pm!!
The disconnection time does indeed refer to the MAXIMUM permissable time taken for a protective device to disconnect the supply to a given circuit should a fault occur.
5 seconds may seem a long time, but in reality it should never be anything like that long if the circuits have been designed correctly and you have MCB's or RCBO's in place.
A lot of the disconnection times date from the days of the old BS3036 rewirable fuses.
In commercial, industrial, temporary installations and structures outside the equipotential zone (outside buildings) the maximum disconnection time should never exceed 0.4 seconds.
