Bullseye 123 on exterior
3 Nov 2008
Hertfordshire
Hi,I'm repainting some external woodwork with weathershield u/c and gloss oik based,I've primed all the bare timber with the primer/preservative but I've some areas where I need a quick drying primer,I've got some zinsser 123 and was going to use this do you think this is ok has anyone else used this under weathershield before.may thanks
Never used it under weathershield, but it is a good all round primer, would be happy to use it myself. As water based avoid damp weather when using.(y)
I've used it before under a gloss oil-based and worked fine!
