- Joined
- 3 Jan 2018
- Messages
- 150
- Reaction score
- 4
- Country
Couple of questions if anyone in the kno could point me in right direction.
I live in a bungalow and am renovating fmy bathroom. I have a immersion heater fo hot water on ground floor and CW. Tank in attic. Planning on installing a dual 3.0 bar pump for a mixer shower.
1) Is it fine / advised to pump the hot and cold up to attic then along and down into shower area? I could pump the entire hot water system and come up from below when doing the flow but prefer idea of using attic due to future ease of access etc.
2) The pump will output 22mm diameter pipe. Do I need to take this all the way to the shower area then reduce to 15mm which seems to be the standard for showers? Or can I reduce immediately near pump and use 15mm pipe?
3) I see a lot of people use a mix of plastic pipes and copper. What's the general rule for best practice here? Should I take copper all way to shower or can I switch to plastic for the final couple of metres and tricky bends etc.
