My brother has recently moved into a bungalow, that has a recently fitted kitchen. The central heating system is an older vented one.
Being a bungalow, the head to the sink mixer tap probably isn't enough. The hot flow/pressure to the tap is lousy, probably as its a modern tap, which may be intended for high pressure systems.
Can anyone suggest a way of boosting hot pressure to the tap? Should I consider a pump or a different type of tap? Alternatively, are there any clever new inventions (something with a venturi???) that may help?
