I am having a patio laid in front of my house. I have the opportunity to put a pipe underground from the back of the property, where my outside tap is, through to the front. This will save me running a hose the 15m or so just to get it close to the cars, front gardens, patio, garage and so on before needing extra length to actually reach anything.
I thought of burying a water pipe with say 0.5m above the surface at each end. I could then add hose connections on those ends where it comes out of the ground. I plan to connect it to the tap at the rear of the house with a short piece of hose when needed. I will then connect a full hose to the far end in the front garden for watering, washing or whatever.
I have looked at 25mm MDPE Polypipe. Would this work? Can you get fittings that go on the end and provide bayonet hose connections? Will it matter that it sits there for 6 months at a time full of water but unused?
Thanks for your help.
