Hi Folks,
I have the following problem with Baxi 105e combi (standard)
Fault 1.Burner extinguishes after 10 seconds with the burner neon light flashing off on CH demand then restarts after 30 seconds same sequence is repeated.
Fault 2. DHW doesn't reach max temperature at all flow rates
Info: Heat exchanger very both sides.
Fault 3. Hot water passing through CH side when taps are on, clean or replace back unit of diverter valve or heat exchanger.
I have been advised to check the min and max burner pressure.
Any advice would be grateful thanks.
