Some words of wisdom gents, if you please....
A guest room refurb.....out with the old 8.5 kW shower, and in with a new Grohe Tempesta of the same wattage.
It's fed with a 6 mm cable, with a run of 12 m approx. the cable isn't bunched, is on top of the insulation and has a fairly straight run.
I've run the shower for around 10 mins, and noticed the cable was a bit warm but certainly not hot. So.....
Do you think it would have been ok to fit a 9.5kW shower instead of the lower power one?
Is there a great difference between 8.5 and 9.5 kW showers performance wise?
Thanks for any suggestions
John
John
