I noticed a funny smell recently when sitting in lounge then I thought it was a blub which had just blown in side table lamp. Then when I went out into garage the PIR light came on which has been outside for about 2 years. I could smell burning again and I looked up and saw the actual PIR light was on but appeared to be smoking!
I have it disconnected now as it was wired seperately so it wont activate now. Is this a likely PIR fault or something in the electric circuit? Nothing else seems affected.
I was earlier adding a light to understairs cupboard off of another light in hallway. The existing light has just one cable in nuetral/earth/live, so I just piggy backed off of this and it worked fine. I disconnected it now as a precaution but outside PIR still burns so off permantly now.
I will get an electrician to pop around to take a check. Its only under 3 years old the house and all else appears ok.
