Hi
Bit of an worrying experience this evening.
Son is having a shower, everything as normal. Then the bathroom is full of a pungent burning smell - no smoke, and the smoke alarms fitted upstairs didn't make a peep.
I switch everything off, and isolate all the different bits and pieces, and sniff out the problem.
The smell was coming from our Triton T80 10.5kw shower. I take the back off, and sure enough locate the culprit.
The input lead which has brown and blue cables goes into a connector box (I think that's what it's called) which holds the cables in place with screws. The other side of this box splits off to the various parts within the shower.
The blue (neutral!) input side cable is scorched, as is the input connector side. The plastic looks slightly melted and the screw is clearly burned.
Oddly, perhaps, none of the fuses, the trip switch for the shower, or the master RCD kicked off.
I'm thinking leave it isolated and alone and get a professional out. But what sort of damage is likely to have been done? Is it going to be fatal to the shower, or is it a minor fault which is more obvious coz of the large currents flowing. Perhaps of greatest concern, why didn't any trip? Usually a lightbulb blowing can trip the RCD!
Any thoughts or suggestions welcome!
In anticipation!
Nick
In anticipation!
Nick
