Hi
I'm renovating the bathroom and we've decided to stick a thermostatic shower in seeing as we've just changed the boiler to a combi and we're now getting decent pressure.
It's going on a thermalite wall and I'll be using the following method to make it work http://wiki.diyfaq.org.uk/index.php?title=Install_Bar_Shower_Valve_-_in_solid_wall,_copper_pipe
I would have bought the fixing brackets but the wall isn't amazingly deep but it'll be tiled with 10mm tiles so I should be ok for depth.
I'll be teeing off of the bath tap supplies but the question is, copper or plastic?
1 - Will it be ok to substitute the bath supplies for plastic, it'll need to run the length of the bath (under the bath, not floorboards) from the other end where it's connected to the sink/toilet.
2 - Is plastic ok to bury and plaster into the wall for the shower or should I go with copper and solder some elbows on where the mixer is to join the pipe? I'm a bit paranoid about leaks and I'm not sure if I trust buried pushfit plastic.
Many thanks
Many thanks
