I have a problem which I think might be my elderly (the sliders barely engage) Potterton EP 2002 programmer but I'd like to get a more expert opinion before I start throwing money around.
The symptoms:
If I switch on the heating alone, it doesn't come on regardless of the thermostat setting (though the "active" light on the programmer comes on so it *thinks* it should be running).
If I switch on the hot water alone it works just fine.
If I switch on the hot water *and* the heating, the heating comes on and burns continuously regardless of thermostat setting. Everyone gets very hot.
So, it's not the three-way valve because that's definitely moving. It's not the thermostat because that wouldn't be affected by the hot water setting. I guess it could be the board in the boiler but I guess that's going to be much harder/more expensive to fix.
I do intend to pop the thing off the wall when I'm feeling brave and just check the wiring is sound.
Any help much appreciated.
The symptoms:
