Buy pre treated wood or treat it myself?
22 Sep 2017
Hi guys.
Going to build my son a climbing frame in the garden, i was going to build it out of 38 x 63 cls timber as it cheap and strong, however the pre treated stuff is twice the price of the untreated stuff.
The treated stuff is pressure treated with Tanalith E. Would this be sufficient to withstand the great british weather without additional treatment?
Or would it be a better/cheaper to buy untreated stuff and paint it or use danish oil something?
Anything timber buried in soil will rot .If you design it to free stand it can last longer.
Treated timber will last longer than any treatment you apply to cls
Either way you need to treat it with tanaline if you have a large tray to soak them in? But you still have to buy the stuff which isn't cheap.
When you dig the holes out, you could stick some course gravel underneath and around the posts a good layer, but it depends what movement it will have
Hi guys.
Pressure treated means that the preservative is pushed into the wood under pressure and penetrates much further in than anything you can apply by hand.
In the gold ole days, when' knights was bold' they used to burn the ends of them. Not sure now effective that is or the use of creasote, nice and smelly and maybe not a good idea where kids are playing.
As lower says. Pressure treated will last longer.
If you are burying the timber then give the section to be buried an additional treatments of Bitchumastic (or a bitchummen / Creosote 50/50 mix) to stop it from rotting. Otherwise it's fencing 'soldiers' at the base of the legs.
