I am buying a flat that has a Devi electric underfloor heating system. The surveyor says that "elements are located within the cement floor screed but couldn't be inspected due to fitted carpets".
All rooms have Devireg 550 thermostats on walls.
I have a few questions:
1) Is it an efficient system? It seemed a good solution, saving space on the walls? However, I noted the seller had a portable electric heater in one room. Maybe underfloor heating takes a long time to start, and warming up a room for a few hours may not be practical.
2) How do I know if it's fully functional before purchasing the flat? Are those supposed to be serviced? Is it possible to get a special survey for this, with heat measurement?
3) How expensive would it be to fix if not working? I guess all the carpets would need to be removed etc? The bathroom has tiles and also underfloor heating.
4) Is there typically a warranty for this? Would it be part of the building warranty (still under 10 years old) since part of the cement floors?
5) Would it be more efficient to replace the carpets by hard wood floors? I don't really know if the carpets were changed after the underfloor was installed, and if their thickness is optimal for underfloor heating
Many thanks,
Tom
Many thanks,
Tom
