I have the opportunity to buy a property built in 1965 for a very good price.
The internals / decor are all original but at least it's all been given uPVC double glazing and re-clad in PVC recently (is a concrete crosswall construction, the front was originally timber clad).
I'm comfortable with the fact there will need to be completely new decor throughout and a new kitchen and bathroom to boot but I'm wondering about the wiring.
The supply to the property is 60A. I would be asking the local energy board to upgrade this to an 80 or 100A supply and provide an isolator switch.
Now, all the wiring is T&E PVC as far as I can tell but it is original. I would say it is imperial gauge given it was installed in 1965. There are three circuits - a 5A lighting circuit, a 30A ring main, and a 30A cooker feed.
The cooker circuit appears to have been installed at a later date as a 30A fuse wire has been placed in a 15A carrier and a 6MM cable fed from the CSU to the cooker, with (the imperial equiv of) 2.5MM T&E disconnected and cut back in the CSU.
I won't be using this as there's a gas feed to the property.
My guess is the 15A circuit was used for the now removed central air heating system that was installed under the stairs with vents feeding hot air around the property.
Now - how much of this is likely to need to be removed? I'm not an electrician myself and would never profess to be but I'm not ignorant of certain things either.
I would like to think I can get away with replacing the CSU, providing equipotential bonding where necessary, and replacing the fixtures (ceilling roses, pendants, switches, sockets, etc) with modern brushed steel equivalents.
I would however look to get a second ring main added for the kitchen due to all the high load appliances in there. I'll be getting a new kitchen fitted anyway so a bit of mess is fine.
I can't see any scorching or discoloration on the current PVC wiring but will have a look in more depth at some point.
So what do you all think? Should I budget for a full rewire when considering my offer to the estate agents? I'm really adverse to ripping the PVC wiring out and replacing it if it's good...
